Need help with 4x4????s
- gregamorton
Guys I have never been big on 4x4s as they break and it can get expensive. My project is not a ford but I am hoping yall 4x4 guys will know or be able to help. I have a 1968 scout 800 with 152 big four with 3speed and twin stick dana 18. The front and rear are dana 27s with 4.27 gears. I am not running a body at all and am going to set the truck up like a buggy with 4 seats and a roll bar setup. The scout is rolling on 36" iroks now and I have a set of 40" iroks to go on 17" wheels. My goal for this setup is for me and my wife and two girls to take it to the river to run small trails and ride on the sand dues. I am hoping to run in 2wd low most of the time and putt around. This is where my main help is needed! I want my rear to be locked and the dana 27 does not have a posi now. I am wanting it to be stout with no issues while we are out and rolling. I am thinking about building a ford 9" and run a full spool. My problem is I cant get a set of 4.27 gears but have found some 4.30s. Can I run the 4.30s with 4.27s in the front?? I have seen 4.09s and 4.10s but thats only .01 difference. Thanks for the help in advance, Greg.
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
- averagef250
Re: Need help with 4x4????s
Greg, it will be fine for what you're doing to run 4.27's and 4.30's. I've run 3.54's in a sterling rear with a 3.50 Dana 44 front and the mismatch wasn't noticeable.
Consider how many people run tires that are more than an 1/8" different in diameter front to back.
- gregamorton
I was hoping for that. I just need to find a narrow 9" that will work better than my bump rear ends. I think when I measured yesterday the bump rear end would make it a foot wider.
I agree with average250. Shouldn't be a problem. Have fun.
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- 71PA_Highboy
Look for an early Bronco 9" (66-77). They are close to the width you want.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- gregamorton
not many bronco's in my area and if the prices are high. I might just go with the wide rear as it just does not matter except for looks! Plus I need to keep the big bolt pattern.
- 71PA_Highboy
I find the bronco housings ~$100... searchtempest.com is your friend...
They have the same pattern as the truck... 5x5.5
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- gregamorton
thanks I will check that out!
- harrysnyder
Weld the spider gears up, can't get any cheaper or easier than that
I build driveshafts.
www.carolinadriveline.com
71 F100, 302, C4, 8.8, crown vic swap
68 F250, 360, NP435, Dana 24, Dana 60's f&r
- gregamorton
I was talking to my friend about that but I have never done that. If welding up with rod what rod should I use for best penetration? How do you get all the slag out and pieces to make sure you get no binding up of other rotating parts? And last how much area needs to be welded up to make sure it does not break loose?
- 71PA_Highboy
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- 1972hiboy
OMG that is histerical! im keeping that link.....
Rich
Dont eat yellow snow.....
