Before I started, I did lots of research, and all I was aware of was the frame width difference and the 2 inch difference in wheel base. I have done some rough measurements and have found that the dent side frame is around 5" longer, when you compare measurements between the rear cab mount and the end of the frame. This is a surprise to me.
I am worried that my rear bumper is going to stick out an extra 4 inches then it should. If I shortn the frame to get the bumper in the right spot, I won't be able to actually mount it due to the spring hanger position.
Is the dent side short box actually longer the a bumpside short box, or am i worrying over nothing. Has anyone had this problem? If so, what would be the best way to deal with it?
Seems like the only option is moving the spring hanger forward 4 inches in order to have room for the bumper mounts.
The shackle angle will be reversed, it will tip backwards instead of forwards, but still clear everything fine. would this be a bad idea?
