Driveshaft Question
Driveshaft Question
Are both 2 piece driveshafts on a manual 3psd column and automatic C6 completely different in length? Will one of the 2 piece driveshafts interchange with either transmission?
Re: Driveshaft Question
Anybody?
- basketcase0302
Dave,
I would have to guess that they are different in length.
Our automatics are usually longer than a standard tranny bolted behind a clutch.
Is the driveshaft on the rearend the same length? I was told the front driveshaft is the one thats different in length for automatic and manual.
- BobbyFord
Lengths are listed here:
F-100...> http://www.fordification.com/partnos/driveshafts_01.htm
F-250 & 350...> http://www.fordification.com/partnos/driveshafts_01.htm
What about using a driveshaft up to a 79 truck?
If i remember correctly the steady bearing mount is the same distance from the trans as in bumpside trucks so I'm pretty sure that 73-79 ones work ,i also think that's what i'm running in my truck right now ( with the front half shortened to work with my trans)but its been while .....
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
Is the splines the same on the C4 and C6 automatic when fitting a driveshaft slip yoke on it?
I don't think a C4 ever came with a bolt on yoke.
Do they both have 28 splines?
there was a truck c4 with a bolt-on yoke,but they're pretty rare compared to the average slip yoke c4'shazelnut wrote:I don't think a C4 ever came with a bolt on yoke.
as far as i remember you can use the slip yokes from a c4 in a c6 and vice-versa ,however the spline count on the slip yoke changed a few times over the years so your best bet is to get the slip yoke out of your donor vehicle and use it with your driveshaft
I was told the output shafts are different in size in diameter.
could,be i'm pretty sure i've used a slip yoke from one with the other before
...i could be wrong tho' its been quite awhile and i was more than likely drunk or stoned at the time
...... but like i said: if you can,get the slip yoke off whatever your trans comes out of and use it with your driveshaft,then you'll eliminate potential problems...
- BobbyFord
If you look at the links that I posted, the "B" measurement is diameter size.davbell22602 wrote:I was told the output shafts are different in size in diameter.
