2wd to 4wd 360 oil pan question
- bike5087
Hello all!
Does anyone out there know if it is absolutely necessary to swap the rear sump oil pan from a 4wd motor when installing a 360 (2wd, front sump) to a highboy frame? It looks to me like there is a ton of clearance between the axle and the oil pan. I've got a 2wd 360 mounted to a 4wd highboy frame but I still have the 2wd pan on. If I could keep the 2wd front sump pan on there I may be able to use the good exhaust from my 2wd. Thanks! and Happy Holidays
- 1972hiboy
Re: 2wd to 4wd 360 oil pan question
hm. Its pretty essential. How did you get a 2wd oil pan bolted into a 4x4 frame? The crossmember is right under the front of the motor. I didnt even think it would be feasible to fit. you sure its a true 4x4 frame and not a 2wd frame that had a front end put under it?
Rich
Dont eat yellow snow.....
You can do it. My first highboy had a 2wd pan if I remember correct. Again if I remember correct I could not get the pan off or on with the motor sitting on the mounts. I had to lift it off thee mounts.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- bike5087
There is a ton of room on mine. I forgot to mention it is a 1973 frame (I think they are almost the same as the 67-72) The cross member is forward of the pan, so I will be able to drop the pan easily. If I can remember how to post a photo I will - according to the vin stamped on the frame it is 4wd I think - F26YRR48524?
A 2wd engine sits at 4.54* and a highboy engine sits at 5.45*. Its easy enuff to swap out pans later for a rear sump but just keep in mind the engine is angled 1* more in a highboy than a 2wd. Ive got a 69 highboy and agree the pan is wide open to get to and change later.
- bike5087
Thanks Hazelnut-
Are you saying the rear sump provides better oiling because of how the 4wd motor sits at more of an angle in it's mounts?
Also - if you've run a 4wd highboy with the front sump pan - was there any clearance issues for suspension travel?
Thanks!
Thanks!
- crewdcab
I've seen front sump pans get munched by the diff. Not normal street driving, but coyote hunting and such.
68 F-100 68 F-100 4x4 shortbed 69 F-100 shortbed
70 F-100 70 F-250 Crew 71 F-250 4x4
72 F-250 4x4 72 F-250 Camper Special Explorer
75 F-250 4x4 77 F-250 4x4 77 F-250 4x4 Crew
- bike5087
I might as well swap the pans out because the exhaust won't work anyway (frame crossmember in the way), looks like I'll have to take it to the muffler shop after all. Then I can go coyote hunting and such!
- 71PA_Highboy
Don't forget you will need a new pickup tube, dipstick and tube, main cap bolt and to plug the old dipstick tube...
I just did mine...
I just did mine...
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
No question in my mind, a truck needs a rear sump.
Kevyn
1972 F-250 4x4, 390, Dana 44, 24, 60
- bike5087
I've got all the parts I need, but I'm not sure how to remove the old front sump dipstick tube (hopefully 71PA_Highboy can chime in on this one). Also - I wonder if 30-06 brass shell will work as a plug. Thanks!
- 71PA_Highboy
The tube is just a push in.... not even a press fit.
Clamp some vice grips on the mounting tab close to the tube, then tap gently.. it should come right out.
As for the plug, since I had the pan off I just used a 1/8 NPT plug with a recessed allen. Tapped the hole and screwed it in. I am sure it won't leak...
Good luck!
Good luck!
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
