Gas Tank Q
fonzf100s
Gas Tank Q
Post by fonzf100s »
Hey all,
I just noticed that in the late 70's the gas tank on a stepside had the filler tube in the rear fender, driver's side in front of the tail light. Am I right that the frame is wider on those, or could a guy mount a tank back there somewhere to get it out of the cab. Thanks,
Ron
Heyyyyyyyyyy, keep 'em cool, keep 'em on the road!
re: Gas Tank Q
No, the rear-mounted tank on the '73-'79 trucks won't fit into a '67-'72 truck, due to the rear frame section being 4" wider. The only exception to this is if you can find the rear-mounted auxiliary tank on a Highboy. The '73-'77-1/2 4WD trucks had an in-cab tank and had frames with the same width as ours, so the auxiliary tank would be an easy swap, but they're kinda hard to find.
fonzf100s
re: Gas Tank Q
Post by fonzf100s »
Thanks, see what I can find.
Ron
bryantracing460
re: Gas Tank Q
Post by bryantracing460 »
When you say they won't fit, is it b/c the tank is too big or the space btwn the frame and fender is too big?
Jeremy
Drive It Like You Stole It.........NO FEAR!
69 F-100 swb 2wd 460 C-6. 86 F-150 super cab 2wd 302 AOD.85 Bronco 4wd 300 AOD.
http://www.myspace.com/bryantracing460
re: Gas Tank Q
Since the rear of '73-'79 frame is 4" wider, so is the tank....it won't fit between the narrower frame rails of the '67-'72 trucks.
bumt72
re: Gas Tank Q
Post by bumt72 »
I ran across this while doing some research on fuel tank options for the 61. Since the frame widths are the same on the 67-72 as the 65 this should work for our trucks as well.
http://www.angelfire.com/mech/jims65/re ... stall.html
Kep
1972 F250 Da Big Ugly Man TruckDa BUMT
1961 F100 Stepside (Father/Daughter Project)UnNamed
fonzf100s
re: Gas Tank Q
Post by fonzf100s »
Thanks man, good link.
Ron
morganater
re: Gas Tank Q
Post by morganater »
I am still a little confused in the whole gas tank respect as to how the hell you end up setting up the gauge sender and the fuel line? :? with an entirely different tank and set-up. Also fabbing a new fuel door would be kinda hard ?
94 Jeep I6 Back-up vehicle
reppin' AK
