translating the codes on a 9" Ford tag
Ozark Tim
Post by Ozark Tim »
Is there anyone who knows how to properly identify the numerical codes on a Ford 9" metal tag that is affixed to the differential.
I know enough to see the axle ratio, but was wondering how to tell if there is a positraction present without removing the differential.
I have a trailer that was made from a 71 F-100 Sport Custom and it has a good bed ( not perfect ) and also the 9" tag says it is a 3:50 axle ratio. Beyond that the other identifying numbers of the tag are Greek to me.
I am not about to give up my 3:00 ratio or my 360 would go from very bad to worse on highway mileage not to mention the excess rpm's, but would try to do some trading to aquire a posi unit for my 3:00's.
If anyone has information that could assist me I would appreciate it greatly.
OT
spartman
Post by spartman »
Either post a pic of the tag or write down what it says and post that.
I believe it has a traction-loc in it there should be an L in the ratio numbers.
IE: 3.00L or something like that.
i'd like to find out that info myself. i've got a 3.25 but thats all i can decifer from my tag also.
RandyBee1
re: translating the codes on a 9" Ford tag
Post by RandyBee1 »
If you want to know if your rear is a posi-trac couldn't you just jack up the back and rotate one of the tires?
Ozark Tim
Post by Ozark Tim »
Yeah I know the jack it up and spin ( or dont ) a tire to see if there is an engagged unit, but it is sitting in the woods at my buddys property and before I go to the effort of dragging a jack through some nasty stuff I would like to have a way to decipher the tag. If not for the ease of that, just to be able to translate them at will in the event that I come across somthing I should want in the future.
I will look at the tag the next time I am out there for an archery hunt and write down what is all on the tag. I definately could see it was a 3:50, but there was quite a few other things stanped there as well.
In the mean time if anyone can help with this please give a reply
If it's a regular open rearend, the ratio will be listed like this: 3 00
If it's a locking rearend, the ratio will be listed like this: 3L00
I have a good chart which can decipher those tags and tell me what kind of vehicle they originally came from, in case you find a rearend that's no longer installed on a vehicle....and providing that the tag is original. If you post your codes I'll look them up for you. (There are so many of them that I've never transcribed them onto a webpage....it would take MONTHS of typing to do!) :eek:
kieth if you were going to post the chart wouldn't it be easier to just scan it? unless it's unreadable by a scanner.
It isn't just a chart....there are 14 full-size (8.5" x 11") pages of codes for the 9" rearends, and another three for the Dana series. :eek: The bandwidth required for hundreds of people to download that many scans would very quickly chew into my monthly allotment. By transcribing them onto a webpage, the entire page will still be less than a couple of the scans and wouldn't make any kind of dent in my bandwidth allotment.
I might have a volunteer to transcribe those codes for me to HTML format, so that they'll be indexed by the search engines, and will then turn up in their results when someone's doing a search. In the meantime, I'm more than happy to look up any factory tag codes that anyone needs info on.
dcbullet
Re: re: translating the codes on a 9" Ford tag
Post by dcbullet »
FORDification wrote:It isn't just a chart....there are 14 full-size (8.5" x 11") pages of codes for the 9" rearends, and another three for the Dana series. :eek: The bandwidth required for hundreds of people to download that many scans would very quickly chew into my monthly allotment. By transcribing them onto a webpage, the entire page will still be less than a couple of the scans and wouldn't make any kind of dent in my bandwidth allotment.
How's the quality of the print? We have software at work that I can scan and then convert it into excel or word, which could then be put into a txt file or at least manipulated to make the conversion to HTML easier.
i didn't that you should do it. i just meant to say if you chose to do it. its really not a big deal to me i was just trying to think of a typing short cut for you.
Ozark Tim
Post by Ozark Tim »
Thanks for the responses y'all. Looks like everyone would love to have the chart for reference like me, but just knowing that they include the L in the ratio ( I suppose for limited slip ) makes it pretty easy to figure. I dont remember an L in the code so I am pretty sure it is an open 3:50 rear end.
Many thanks again for your assistance on this and if anyone ever decides to post the charts with refernce to decoding these differentials I will be all eyes.
OT
fuzzier1
Post by fuzzier1 »
Ozark
Is there a N molded into the third member just above the yoke? If there is I will buy it from you regardless of the gear ratio. :D
Fuzzier
