Need to Plow
JoshDacres
Need to Plow
Post by JoshDacres »
Hey there- I've got a '67 F350 and I need to get her a plow- my only problem is that I dont really know anything about plows. I mean I dont know what to look for to put a plow on my truck, like what kind of mount, what kind of plow, what kind of hydrolic control or electric. Any help would be awesome...
Also found a craigslist add in my area for an 8' plow with the entire set up, harness, mounts, lights, all of it. Its on a late 80's blazer though, so Im assuming that the mounts and wiring wont be the same.
Haha- Im lost... help
forrestbump
Re: Need to Plow
Post by forrestbump »
I have absolutely NO experience with plows, but armed with a tape measure, measure your front frame horn dimensions and compare them to the mount dimensions on the plow from the Chebby Blazer. If reasonably close, I would assume you could adapt the plow to your Ford.
As far as the plow goes, is the Craigslist plow still attached to the Blazer? If so, ask the seller to demonstrate it for you. If not still attached, you're probably on your own...pig in a poke.
I hope more knowledgeable members will chime in for you.
1970, 2WD, F-250, C/S, Dual Tanks, 390 FE (of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Sky View Blue, Ranger XLT
1970, 2WD, F-250, C/S, A/C, Dual Tanks, 390 FE (again, of course), C6, Power Steering, Power Disc Brakes, Dana 60 3.73, Wimbledon White & Sky View Blue, Ranger (almost twin brothers!)
"One of the greatest discoveries a man makes, one of his great surprises, is to find he can do what he was afraid he couldn't do" - Henry Ford
Larry
JoshDacres
Re: Need to Plow
Haha yeah thanks- The plow is not on the blazer, figures. :D
1971ford
Re: Need to Plow
Post by 1971ford »
ahh, i know.
Get the plow, get a blazer. Mount plow to newly acquired blazer. Take blazer and plow snow, until it rusts away, then your bump doesn't get harmed and one less chevy out there.
Just kidding.. although it is a possible scenario :wink:
-Ryan
CrypticRacer13
Re: Need to Plow
Post by CrypticRacer13 »
:yt: :lol:
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
cep62
Re: Need to Plow
Post by cep62 »
So are you going to plow commercial or just a drive way or two.?
I've had good luck with Western.
The cable operated electric ones work good if they're set up right.
The newer all electric ones are faster, but they also cost more.
If you can weld and fabricate, these old Fords are pretty easy to adapt to.
In my area Western ,Fisher ,Meyer, and Boss seem to be the most popular.
If you're going to plow a lot I'd get an automatic and power steering. :2cents:
Stay away from the ones that drive off your fan belts they're slow.
cep62
Re: Need to Plow
Post by cep62 »
I'd check the website of the plow manufacturer .
maybe they have a sketch of a mount set up.
try '79 and older ford. :2cents:
akforceten
Re: Need to Plow
Post by akforceten »
Here's a pic of my 72 ford with a Meyers plow set up. the frame mount cost about $800 but it looks like someone could fab up the mount easily.
