NP205 transfer case yoke?
Moderator: Doug Comer
- mlheppl
On a married 205 trannsfer case is the yoke for the front driveline the same size for a Dana 60 front axle as the Dana 44 front axle?
Mike
71 F250 4X4
99 F250SD 4X4 7.3L PSD
71 F250 4X4
Re: NP205 transfer case yoke?
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- averagef250
I looked at the 78-79 60's I have here and both have 1330 yokes on them. I think the last 78-79 44 I had was 1330 also. I know the 80's and 90's F-350 4x4's used 1330 CV front shafts while the lighter trucks often had 1310's. Lots of stuff gets changed over the years so I'm not going to say anything I saw was from the factory that way. 1310's are usually strong enough for a 1 ton front driveshaft. I've put some power through 1310 CV's as a rear driveline in a lighter truck and it worked fine.
