That looks like a braket for a towing reciever of some kind. It is definetly not factory. I would grind it off at those welds. I have carage on the back of my 70 that shows how bad it can get if you try and cut off something with a torch.
Bill
2012 F-350 PSD FX4 LWB CC lariat, white http://www.fordification.com/galleries/ ... hp?uid=602 "If you want to judge a person's true character, give them power."
I think it's a mounting bracket for different lights for different bumpers. On my truck a set of lights for the chrome bumper (it has the original farm bumper on it) is mounted on it.
1969 F-100 Short Bed Custom Cab 390
1985 BMW 635CSi
If this is on a Camper Special, I'd almost bet it's for the Factory Installed Rear Camper Bumper that was adjustable. My 68 F250 CS had a simular type (if I remember correctly). The bumper had long C shaped rails with an X brace support from one side to the other. It should have another just like it on the other side. This allowed the owner to slide it in and out for the lenth of the camper. Ray
my 67 has a slide out bumper and it doesnt use that bracket at all. but it may be different than other slide out bumpers. mine has the slide part in the center. and you unbolt the center bar as both frame brackets and it slides right out. i can only guess that it has to botl to the camper with the bumper brackets. because the center doesnt have a bolt up place once it is slid all the way out.
