gear ratio
boots
gear ratio
Post by boots »
i have ae 9" rear and am wondering about my gear ratio. I see all sorts from 3.07 - 5.83. I want better acceleration, and can these new gears get me somewhat better gas milage? What should I go with?
Also seen ratios for the trans? What would get me the best performance here?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
GT-Racer
re: gear ratio
Post by GT-Racer »
depends on a lot of factors. if you run bigger tires, then you should get more gear to turn the motor the same RPM's. The higher the number the better the acceleration, but higher the rpms at cruisin speeds. Lower the number , harder to get started but runs along easier at speed.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
boots
re: gear ratio
Post by boots »
ahh ok, So im thinking of getting 3.89 with stock tires. And I may get 33's in the long run. Dont look like there will be a long run with gas prices though :o
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
bwc302
re: gear ratio
Post by bwc302 »
A lot of folks go in between to get the most of both performance and mileage... somewhere in the range of 3.50 is a fair trade off.
The lower numerically (higher gearded) 3.25 usually will get better mileage but less performance that a higher numerically (lower gear) 3.50.
Good luck
oldhalftons
Post by oldhalftons »
with stock or 33" tires, 3.50's are a good balance of economy and acceleration
1969 F100 300/4spd power steering, manual brakes
fordloaf
re: gear ratio
Post by fordloaf »
For a F100 i sould say around a 3.5. If you dont drive on the interstate then go with a 3.70. I have a 4.10, but it is a F250. If i never hauled stuff i would have prefered a 3.73 but even on the highway my 4.10 does fine at 80mph.
willowbilly3
re: gear ratio
Post by willowbilly3 »
The 350 is a good all around gear unless you are going real tall on the tires. Just remember that you need the carrier too if changing from a 3. to a 4. or lower.
