Firewall question.
OldRedFord
Firewall question.
Post by OldRedFord »
What can I do to better seal where the heater core pipes come through the firewall?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
BobbyFord
Re: Firewall question.
Post by BobbyFord »
Take a round, thick piece of material, such as rubber, with a 5/8" hole in the center and slide it onto the heater core pipes before you put the hoses on.
ford made regular rubber seals to go around the hose holes. i dont know if you can get some from a vendor or just walk into the parts store and buy something like that. they would be similar to a protector for for electric wiring going through a piece of metal like a firewall.
robroy
Post by robroy »
Hey Tim!
I haven't tried this stuff, but you could give it a whirl. It looks easy to apply, at least.
http://www.eastwood.com/autobody/seam-s ... 20-yd.html
Robroy
70_F100
Post by 70_F100 »
robroy wrote:Hey Tim!
Robroy
When I worked for an AMC/Jeep dealer back in the early 70's, we used a lot of that stuff for sealing around cables, hoses, etc. It works pretty good, and is easy to use.
I would research what Fordman said about the grommets. That would provide protection against chafing of the heater hoses, where the caulk would not.
That's not an oil leak :nono: That's SWEAT from all that HORSEPOWER!! :thup:
flyboy2610
Post by flyboy2610 »
The seals are available from LMC.
#26 on this page:
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=54
