RADIO REPLACEMENT
capeclassics
RADIO REPLACEMENT
Post by capeclassics »
My '70 Sport Custom has the underdash A/C......how do you get at the radio and dash speaker to remove replace without tearing out the A/C unit?????Help!!!
dcbullet
re: RADIO REPLACEMENT
Post by dcbullet »
If you take out the glove box liner is there still not enough room to pull it out of the glove box hole?
Joe Kriston
Post by Joe Kriston »
Ed,I think DC is right,...your best bet would be taking the glove box liner out....Your's is pretty new,so you should be able to remove it w/o tearing it up...Also,you'd have to loosen all the heater control cables if you went from underneath....You may have to also remove the ash tray assembly...BTW,I noticed I still had the original speaker bracket sitting here on a shelf....Lemme know if you'll be needing it and I'll send it to you...
dcbullet
Post by dcbullet »
I would imagine even after taking out the liner it will be tight. I recently installed the factory AM radio back into my truck and there were some scuffed knuckles. I don't have A/C and your glove box liner is smaller for a reason, the A/C protrudes up into that space.
Personally I would attempt to do it without messing with the heater control box because it's kind of a PITA to remove and replace, IMO.
Good Luck.
68F250
Post by 68F250 »
You could pull the instrument cluster & ashtray and try from that side.
Barry
capeclassics
Thanks guys,I'll let ya know how I make out.
