door wiggles
hotrod ford
door wiggles
Post by hotrod ford »
today when i was stripping the cab down i noticed that the drivers door will move up and down on the hinges i guess. i looked at where the door connects to the mounts and the mounts to the cab. neither move so i think it is the hinges. how do i fix this?
mljjones67
Re: door wiggles
Post by mljjones67 »
sounds like the hinge pins are wore out.
BobbyFord
Re: door wiggles
Post by BobbyFord »
DC sells hinge pin/bushing kits. Very easy fix.
hotrod ford
Re: door wiggles
thanks guys. :thup:
Banjo
Re: door wiggles
Post by Banjo »
how do you replace door hinge pins on these trucks? You unbolt the door from body and do you drill out or cut off old pin and install new one and bolt door back up? Never done it, so I'm asking, read this and thought about my driver door sag. Banjo.
jzjames
Re: door wiggles
Post by jzjames »
Take the door off, you can use a scissor jack or something underneath it for support to make the job easier - it's heavy. You will see the hinge pins and bushings are easily replaced as long as the hinge pins did not wear completely through th bronze bushings and oblong the hole in the hinge itself.
The 'Help' door pin kit can be gotten at the parts store, it's Help# 38402 that you need.
jz
