Ok guys I have a few questions.
I just picked a F350 parts truck. It has a dually flatbed rear dana 60.
assuming it will bolt into my '72 F260, what would I be looking at to swap the trac-lock (posi, whatever) from the existing rear end into the dually rear axle?
I originally was going to use only the dually outers on my old rear end, but the dually rear has the right gears for my 4wd (to match the front, something the old rear end in the '72 does not have, due to being changed on the side of the Hiway in nowhere, nevada on a friday afternoon after I blew the original axle out)
so here are my options-
1) install the dually outers on the current posi rear in the truck, then change the gears to the correct gears. (and I have a gear set already for this). I have never messed with gearing, so it would have to be farmed out to a shop.
or-
2) install the complete dually rear in my truck then figure out how to install the posi set in this housing. would this have to farmed out, also? or can a shadetree mechanic like me do this?
does any of this make sense? I need to do this as cheep as possible due to lack of funds until the Kid is 18 or so. any ideas of pricing?
rear diff swap questions
- 72hiboy4x4
re: rear diff swap questions
Are you sure that F350 has a Dana 60? I was with the understanding that all F350 duallys came with an Dana 70.
- 72hiboy4x4
- 72hiboy4x4
well it is a dana 70. with the 10000 gvw, I shoulda guessed as much. good call Keith!
Ok my ?'s change to this- can I use the dually outers from the d-70 on my d-60, thereby having duals and keeping the Posi also. I will still have to drop my new gears in the d-60 eventually, I know.
I dont think putting the d-70 under my truck is an option now.
- customcrewcab
my truck had a dana 70 under it. just remember the the the driver side is oppsite treads. i got 500 out of mine when i sold it.
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
