frame mount tranny cooler
Have any of y'all run across a frame mount oil cooler... I had a aluminum one long ago and can't find one...all I can find is the ones that look like a mini radiator.. I want a long one I can run outside of my frame rails????
Re: frame mount tranny cooler
you can put it anyplace you want to really. the more air flow the better though.
They say transmission but I'm sure you could use it for regular oil.
http://cgi.ebay.com/ebaymotors/20-ALUMI ... A15|39%3A1
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- lee_ford
That LOOKS cool. But you would need more than one installed in parallel. The one on ebay has only 1/4 inch fittings and that is not near enough flow to use in line with a remote oil filter hookup. All transmission coolers have small lines to flow only what goes through the stock coolers in the bottom of a radiator.
Check out these guys…
http://www.dana.com/Automotive_Systems/ ... edeoc.aspx
They have several types of engine oil coolers. Their power steering oil coolers look good too and could be adapted to engine oil cooling.
Here is a page with Ford part numbers and diagrams too…
http://429mustangcougarinfo.50megs.com/oil_cooler.htm
Just do a Yahoo search for “Oil Cooler” and look around. I bet you can find one that looks good to YOU. If it is made to fit a VW or whatever, who cares, as long as it looks cool to you.
Lee
Lee
My 1969 F100 Gallery
[Please note: A lot of what I write may be common knowledge to some of us. But for a new comer and even us at one time, somebody had to inform us that FIRST time.]
Thanks mrsnicks that is exactly what I need...I just will need one longer...I guess from the other replies that I did not put it in bold that I don't want a mini radiator style.......even the title says "tranny" cooler.... Dunno what fordman has been smokin ( yeah I can put it on the roof for max air, but want it on the frame) musta been good.....share man share....thanks again guys ya pulled through for me...I did find some coolers like this yesterday at a old hot rod shop...but the were much more expensive...the 20" was 50 bucks...so I do ty ty ty
Here's a 30" for 51 bucks shipped.
http://cgi.ebay.com/ebaymotors/ALUMINUM ... A15|39%3A1
And in defense of the people who mentioned oil coolers, the first line of your post is :
'Have any of y'all run across a frame mount oil cooler'
Patrick
Patrick
Chevrolet
Your the best !!!!!!!! the photo on the ebay showed the vender and I can get the 30" for less than 1/2 of what the hot rod shop here wants....Can't thank ya enough.... oh I didn't mean to offend any peeps... was clownin around....
what i meant is that ihave seen people put the coolers up on hte inner fender. but that really will not get air flowing through them. it has to have air flow like a radiator. atleast the old style types do. im not talking about the type that goes inside of the bottom radiator tank. im talking abou tthe type that has the tube that winds around and is connected with aluminum fins.
