Thank you!
If the rating is the same as for an 80,000 Semi, then that 5000 lb weight includes the trucks 3580 lbs. I just cannot see an F100 hauling 2.5 Tons of CARGO without sitting down on the snubbers. That would be like putting another F100 in the bed with 1420 lbs of cargo in that trucks bed.fordman wrote:… it is weight rated at 5000 pounds from the factory. which mean it can haul upto 5000 pounds on the suspension with out hurting anything.
you are right i have been having a bad few last days. i got my numbers all mixed up. i had 5000 pounds in my head from the gvw. not the bed carring weight. ignore the numbers i put up. im sorry.1970f100x wrote:1000 pounds is half a ton..
