Broken handle on column shifter, where to find new one?
I've been looking at autozone, jcwhitney, napaonline and a few others to try and find a replacement column shifter. The one in my truck is broken and held on by tape. I'm not sure the extent of the damage but I'm hesitant to remove the tape to see until I can find one to replace it or I might not get it to work again.
98 Prelude
05 Magnum R/T
69 F100 360
05 Magnum R/T
69 F100 360
Re: Broken handle on column shifter, where to find new one?
the collars are available from the parts vendors on the links page. or you could try posting in the parts wanted for a good used on. more than likely the hole for the roll pin has worn out thats why the tape is on it to hol dit in place so it can be shifted.
Oh cool I found one on LMC, thanks!
98 Prelude
05 Magnum R/T
69 F100 360
05 Magnum R/T
69 F100 360
