fuel comes out of top of carb
sacramento_ford
Post by sacramento_ford »
i pointed it to the needle valve but it has a new one and even has a new washer,,,not rusted, maybe the wrong one? are they the same
Re: fuel comes out of top of carb
the float is stuck.
When you ask a question, you're going to have to spend a minute or two thinking about what you want to say, then type it out, and then re-read it out loud, as if you you're a forum visitor....and make sure it makes sense. I have no idea what you're asking here. Also, some more pertinent information on the model specifics might go a long ways in getting someone to help you out. Just an FYI. :wink:
sacramento_ford
FORDification wrote:When you ask a question, you're going to have to spend a minute or two thinking about what you want to say, then type it out, and then re-read it out loud, as if you you're a forum visitor....and make sure it makes sense. I have no idea what you're asking here. Also, some more pertinent information on the model specifics might go a long ways in getting someone to help you out. Just an FYI. :wink:
uhhhh ford man knew what i was talking bout.
not really the title said it all. i have no idea what a wore is though. in your other post.
NM5K
Post by NM5K »
Even new float needles, etc can get stuck open. All it takes is a small piece of dirt, rust, etc..
You'll have to tear it apart again to see what the deal is. Probably a speck of rust keeping the
needle from seating tight.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
