hi, anyone got a 390 spark plug wiring for 390
sacramento_ford
Post by sacramento_ford »
retard boy took them off and has no idea where they go, i tried to look for pics on the internet but its hard to tell,i saw a good one for a 360 but i got a 390. not sure if they are the same. i think i got em backwards
convincor
Re: hi, anyone got a 390 spark plug wiring for 390
Post by convincor »
same as 360.
here's a pic fordman posted
"Still Plays With Trucks"
sacramento_ford
convincor wrote:same as 360.
rad thanks
dolinick
Post by dolinick »
Not to confuse anyone but when I put the distributor in and hooked up the wires in my 360 I believe having the ignition timing out 180 degrees helped lead to backfire and bending of my pushrods.
I believe rotating the engine till number one is back at TDC or 6 degrees BTDC solved this. I hope I'm not adding confusion by saying this.
Dan
2003 7.3L F250
1968 F500 Utility Truck
