I found this rear end, will it swap into my 72, it is from a 77?
3.50 geared factory 9 inch limited slip
He is also selling a 4 speed granny for $100 if anyone is interested, craigslist Dallas.
rear end swap
rear end swap
Don
1972 F100
1967 Galaxie
2004 F150
1972 F100
1967 Galaxie
2004 F150
Re: rear end swap
It won't just bolt in, but it can be modified to fit. A 9" rearend would've only been available on F100/F150, and the frames on these trucks were widened out 4" from the cab back, so the spring pads welded to the axle tubes were spread out 4" accordingly. Therefore, the only way it'll go into your truck is to relocate the spring pads back to the narrow-frame position.
- willowbilly3
Re: rear end swap
It seems like an easy modification and you end up with a rear end that is the correct width instead of too narrow like the stock original one.
Re: rear end swap
Ok, cool. :)FORDification wrote: ...the frames on these trucks were widened out 4" from the cab back,
I'm thinking... buy new spring pads and weld them on using the originals as a reference to
get the angle right etc. Would it hurt anything to leave them on and never cut 'em off? :)
Alvin in AZ
Re: rear end swap
Not all all, aside from the aesthetic aspect.
