hooker super comp headers for a 460
prostreetjim
Post by prostreetjim »
Well my question is has anyone had any experience with the hooker super comp headers on a 72 with a 460 that has the correct motor mounts. I've read a lot about headmans, does the hooker go above the crossover, they look might long in the pics in the summit catalog. They sure cost way more just thinking they will fit better? :?
70shortwide
Re: hooker super comp headers for a 460
Post by 70shortwide »
I have asked around about any headers that will fit (above the crossmember). ive heard both ways about the hooker super comps. the only headers that Ive heard sure things about are sanderson shorties. I called them and they said they would guarentee them to fit. The only reason ive held off is to search the portland swap meet this weekend. If you decide to try the hookers or hear anything solid on them I would surely like to know.
SVT522
Post by SVT522 »
The Hooker Super Comps go over the cross member between the radius arms then go under the tran cross member.
SVT522
ASE Master Automotive & Medium/Heavy Truck Technician
"The Speed Bump" 1967 F100 - 466 "Cobrajet", C-6 trans, 4.11 Detroit Locker
1969 F100 4x4 - 360, NP435, Dana 21
1973 Mach1 - 351 CJ, C-6, 9-Inch
1996 SVT Cobra #522
1987 F-250 4X4
70shortwide
SVT522 wrote:The Hooker Super Comps go over the cross member between the radius arms then go under the tran cross member.
no worky for lowriders. thanks a bunch! :thup: may have saved me some grief.
