Aluminum FE vs. Iron FE
mrtleavitt
Post by mrtleavitt »
Okay what's the pros and cons of these two motors?
Is there anything really besides weight? What is the weight difference?
Dragon
Re: Aluminum FE vs. Iron FE
Post by Dragon »
Aluminum FEs are all aftermarket and Dove had a casting problem that is resolved by now. Aluminum saves up 200 lbs on a FE. And aftermarket Aluminum and Iron FEs can be ordered set up with different stock bores and crank clearances.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
390F100
Post by 390F100 »
$$$$$$$$$$$ Too rich for my blood, i'll stick with my overweight cast iron block/heads.
390
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
