Drive shaft / drive shafts
bmerkley58
Post by bmerkley58 »
I would like to know what the drive shaft set up was from the factory when a short wheel base truck had a T85N overdrive transmission.
Did they use one drive shaft or did they use the two drive shaft and carrier bearing set up?
Bob
Re: Drive shaft / drive shafts
SWB trucks never had a two-piece driveshaft AFAIK. It wasn't necessary.
SportCustom
Post by SportCustom »
I have an original t85n truck and the drive shaft is a one piece but does have a slip yoke on one end. This slip yoke allows for about 3-4 inches of adjustment. Heres a pic of the yoke I was referring to.
Todd
1970 F-100 Sport Custom
390 FE
CV/8.8 Swap
SportCustom wrote:I have an original t85n truck and the drive shaft is a one piece but does have a slip yoke on one end. This slip yoke allows for about 3-4 inches of adjustment. Heres a pic of the yoke I was referring to.
http://www.fordification.com/galleries/ ... nshaft.jpg
Todd
what is the total collasped length on that thing from center of u joint to center of u joint?
SportCustom
I can get some measurments when I get home tonight.....
390 FE
CV/8.8 Swap
SportCustom
58 1/8th center of u-joint to center of u-joint
390 FE
CV/8.8 Swap
thank you. no ifi can find the one i have around here i can remeasure it again.
bmerkley58
Thanks for all the information. When I first tried to determine the drive shaft length the transmission wasn't bolted to the bellhousing and I somehow came up with a length of 72 inches center to center at the u-joints. This seemed very long and I heard you generally don't want the drive shaft to be over 60 inches long so that is why I thought maybe it required two drive shafts. Obviously I figured wrong because I re-measured and came up with 58 1/4 inches center to center at the u-joints.
Bob
BobbyFord
Post by BobbyFord »
Should be a D0TZ-4602-AA driveshaft.
SportCustom wrote:58 1/8th center of u-joint to center of u-joint
i found mine earlier and i just measured it. it must be for what i thought it was for . a front drivesahft for a 4x4 because it is 52 inches collasped from center of ujoint to center of ujoint. thanks for the confirmation on that again.
