Those of you with a 302?
JMcTurnan
Post by JMcTurnan »
Well I have a 302, and it runs hot. Normally 1/2-3/4, my dad said it should run about a 1/4, what does your guys run?
bsokie
Re: Those of you with a 302?
Post by bsokie »
Not sure on factory gauge what mine runs. Have an aftermarket gauge and it runs about 190. Not sure if that helps or not.
Lar4t9r
Post by Lar4t9r »
JMcTurnan wrote:Well I have a 302, and it runs hot. Normally 1/2-3/4, my dad said it should run about a 1/4, what does your guys run?
I run both factory and aftermarket gauges. Factory 1/4...after market 160.
Laurence (Proud owner of 1969 Ford F-100 and 1970 GTO)
the ford thermostat should be a 192. but you could go down to a 180 degree thermostat.
HillbillyDelux
Post by HillbillyDelux »
dont know about quarters but mine hangs out around the m on the factory gauge and ive got aluminum rad and elec. fan
2000 Ford Ranger 4x4 "DD"
2003 Cobra
"If it ain't broke fix it til it is"
drytoast
Post by drytoast »
My temp gauge doesn't even move. Hmmmmm maybe I should get that fixed if some warm weather ever gets here. :D
Life is hard; its harder if your STUPID. John Wayne
1972 Ford F-100 Explorer 302 C4 automatic
2005 Chrysler T&C Limited
1996 Honda Accord LX 238,000 miles and counting
JMcTurnan
Post by JMcTurnan »
So mine is running hot then, what do you think problem could be, just redid manifold gaskets, only other thing i could think of is head.
Joshpow
Post by Joshpow »
Mine won't even get into the low normal range. It runs around 175 at the warmest unless I sit in traffic. I never have good heat during the cold months for that reason, but it sure is nice when it's hot outside to not worry about overheating.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
FordTruck
Post by FordTruck »
The 302 in my 70 runs about 160 to 180 usually,but I haven't driven it enough to know what it'll run for shure.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
bsokie
Post by bsokie »
Might want to check and make sure thermostat is working correctly
papabug71
Post by papabug71 »
Mine runs between 180-190 all day long. I know a guy here in town that had a 302 in his truck. He rebuilt it, but when he did, he had it bored out to no end. .060+ That thing would run hot in a blizzard.
Has your 302 ever been bored all the way out???
Your first upgrade should be a good set of under dash gauges. That way you can see exactly how hot its running. That 1/2 to 3/4 stuff is for the birds.....
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Lar4t9r
Post by Lar4t9r »
fordman wrote:the ford thermostat should be a 192. but you could go down to a 180 degree thermostat.
I added the after market gauges 'cause I didn't trust the stock gauge. I was a little concerned with the 160 temp thinking it was a little low, but it runs good and never rises much even in stop and go traffic. Ifigure rather than changing the thermostat so it runs hotter, I'll just keep an eye on it and see how it goes.
Now as far as what to do for running hot, I had a SS 396 a few years ago that was doing that...every time I stopped it would puke anti-freeze. I thought it was a bad thermostat, changed it but no improvement. Then a mechanic friend suggested having the radiator cored and that solved my problem. Just a thought. :2cents:
JMcTurnan
Post by JMcTurnan »
Yea I am using the dash one, I could try to pick up another, its never been bored all the way out, and just replaced thermostat.
thebannister8
Post by thebannister8 »
right manifold gaskets...not blocking any passages :?
...whenever i get a new thermostat...i always boil it to make sure the thing works..
you may also want to run it without the thermostat to see if it will cool down more.....
fan clutch ok ( if you have a fan clutch ) :?
radiator full of gunk :?
hoses crimped :?
sending unit correct :?
JMcTurnan
Post by JMcTurnan »
Everything is good, except I dont have original fan, so no clutch.
