firing order
emilo2008
firing order
Post by emilo2008 »
from where do i start from the dizzy? it has the order on the manifold but i dont know where to start from the dizzy. also does someone have a diagram of the carb?
dantheman71
Re: firing order
Post by dantheman71 »
If by dizzy you mean distributor I believe they usually have a mark for where the number 1 cylinder is?? If not try this link and make sure #1 is at TDC and go from there. Hope this helps
http://www.aa1car.com/library/ford_firing_orders.htm
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
