Option for an O/D trans with an FE
two-bit
Post by two-bit »
Since i am running a truck with a 159" W.B., i figure i have some room to work with in my drive shaft length.
So i am looking into the costs of installing one of these in a divorced application.
http://www.high-impact.net/dualrangeoverdrive.htm
I can keep my FE, my NP435, and not only gain O/D, but extra gears for pulling heavy loads.
Just an option I thought I would bring up for your consideration.
It might not be real practical for a day driver/cruiser. However i think it would be great in a work truck for towing and heavy loads.
Two-bit
70f350
Re: Option for an O/D trans with an FE
Post by 70f350 »
My Dad had one of these in his motorhome and never had any problems with it. They are pricey though. Have you looked at the Ranger overdrive units? I knew a guy who had a Ranger od in a 73 4x and he loved it. Gives you 8 forward gears and 2 reverse gears, you have to deal with another stick though.
Check these out.
http://broncograveyard.com/bronco/i-31525_froogle.htm
http://www.fordification.com/torque-splitter.htm
“If everybody is thinking alike, then somebody isn’t thinking.”
- General George S. Patton.
averagef250
Post by averagef250 »
Have you searched around for an old brownie? I come across ones from the 50's and 60's now and then that are great for pickup size use. Most are under or under-under units, but you can install them either direction and if you find an under-under unit you can just remove one of the gearsets to make it two speed.
Fordnatic
Post by Fordnatic »
I always wanted to find a brownie. I did hear that they are straight cut gears and whine pretty loud. Anybody know for sure?
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
willowbilly3
Post by willowbilly3 »
I had a nice small one in a 0ne ton International. It was a 3 speed with a deep reduction 1st which you really didn't use and a direct/over. I wish I still had it. I am on the trail of a couple of those small "browny" (Browning I think) trannys locally. I found a guy on ebay a few years ago that was selling them for 600-700
Fordnatic
Post by Fordnatic »
I thought they had an over/under/direct. Was it straight cut gears with a whine?
55F100
averagef250
Straight cut do whine. The smaller ones I've seen have been "Brown-Lipe" a division of Dana-Spicer. They all had helical gears and were pretty stout inside. They're about the same size, a bit less height though, than an old truck 4 speed.
I've never actually seen one that was an overdrive unit. They were all underdrive units, but the only thing that really effects which way you mount it is the speedometer connection. You can put them in forwards or backwards. Just backwards the speedo won't read right when not in direct gear.
70f350
Post by 70f350 »
What trucks did the brownies come in?
Redcap
Post by Redcap »
averagef250 wrote:Straight cut do whine. The smaller ones I've seen have been "Brown-Lipe" a division of Dana-Spicer. They all had helical gears and were pretty stout inside. They're about the same size, a bit less height though, than an old truck 4 speed.
Granddad has an old gasser IH dumptruck with a 3speed brownie, under/direct/over. He also refuses to let me buy it.
