3 spd and 4 spd bellhousing and flywheel
Weather-permitting I will be heading to the junkyard on Saturday to look for a bellhousing and flywheel for my T-19 swap. To expand my options, are they the same for 3 spd and 4 spd trucks? Engine is an FE.
- SportCustom
Re: 3 spd and 4 spd bellhousing and flywheel
Bellhousing should be the same.......If you are going to buy a new clutch then you may want to hunt down a 12 inch flywheel for the larger clutch. Not necessary just added insurance.
1970 F-100 Sport Custom
390 FE
CV/8.8 Swap
390 FE
CV/8.8 Swap
the bellhousings are the same i think for an fe.
Truck FE bellhousings are the same. Car FE bellhousings are 7/16" shallower in depth and won't work without a car-type manual transmission.
