CONFUSED ON TRANSMISSION TYPES
dvdsorrow
Post by dvdsorrow »
I HAVE A 68 F100 2WD WITH GRANNY GEAR TRANSMISSION REVERSE IS OVER AND UP
I JUST GOT A 72F100 4WD WITH GRANNY GEAR REVERSE IS OVER AND DOWN {BOTH TRANSMISSIONS ARE OVER TO THE RIGHT}
THE 68 SEEMS TO HAVE A SLOWER GRANNY GEAR AND SLOWER REVERSE IS THIS RIGHT,AND COULD ANYONE ID THESE TWO DIFFERENT TRANNIES
THANKS DAVID
mmerlinn
Re: CONFUSED ON TRANSMISSION TYPES
Post by mmerlinn »
No one can ID them unless you provide enough information.
AND GET RID OF THE ALL CAPS!!
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
Sazman
Post by Sazman »
Hello David
The over and down tranny is a NP435, lots of info about here on the site, the over and up is a T-18, again, lots of info about it if you'll search a little. Both excellent transmissions though.
1965 F-100 300-6 working on it, wanted a first year Twin I-Beam 300, now I gots one
1971 F-100 Custom 302 C4
1962 F-100 Custom Cab 292 3 on the tree, restoring, probably gonna sell it I guess. Love the engine.
1972 Maverick 2 DR 250 I-6, C4, restoring.
1978 F-150 always wanted one of these too. 300, 3+1 OD trans, pretty well preserved, working on it
1985 F-350 460 crew cab, rough as a cob
All these are southern Arizona desert trucks, little to no rust, but the sun takes its toll,ha.
papabug71
Post by papabug71 »
:yt:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
dvdsorrow
Post by dvdsorrow »
Thanks for the info everyone,didnt mean to offend anyone with my caps locked,thats a bad habit of mine when typing ,im not very good at it.Ihave found several discussions about the 2 transmissions,but they get a little confusing.I have found only one that seems to point toward the np435 being faster geared than the t18.
Thanks david
willowbilly3
Post by willowbilly3 »
mmerlinn wrote:No one can ID them unless you provide enough information.
You've been here for a couple weeks with 26 posts and now your a mod? Look around, this board isn't the HAMB. Be polite.
Alvin in AZ
Post by Alvin in AZ »
Doggonit, they changed where the reverse is so much, there's no ID-ing it that way.
Get the tags off 'em, don't mix 'em up and type out what the ID tags say. :)
http://www.panix.com/~alvinj/file12/Ftags.jpg
Might as well get the tags off the rear axles too while you're at it. ;)
The two upper tags are rear axle tags. (Ford 9 inch)
The two lower tags are transmission tags. (Warner T18)
http://www.novak-adapt.com/knowledge/tr ... ateway.htm
Alvin in AZ
