C6 shifting early, how can it be changed
I recently changed the intake to a 4 barrel and did a shift kit in the trans, now with the increased vacuum to the modulator, the trans shifts early. The modulator is not adjustable, can I put some sort of orifice in the vacuum line to cause the trans to shift later? I did a quick test with the valve I pulled off of the distributer (mine is "green", I understand that they are different colors for different delays in vacuum advance to the distributer) and it certainly helped. Any thoughts or suggestions would be appreciated.
re: C6 shifting early, how can it be changed
Vacuum modulators are also available for auto tranny's in an adjustable version.
Jeremy
1971 Ford F250 CS, SC, 2X4, 390, C6
How hard are the modulators to replace?
- 67F250CS
5 minute job with a pee break included.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
Your right, easy 5 minute job, however the first run the trans shifted at about 3000 rpm with my foot in it, so I turned the modulator screw in 1/4 turn and there was no change. Then i turned it out 1/2 turn no change. After much messing around with I got the thing so far out of wack it never shifted that high again even with the modulator screw all the way in. I bought another one just to give it a shot and it still wants to shift early. Does anyone know what the color band signifies on the modulator. Mine is a purple band push in regulator.
- 68F250
Here's a good thread on shift speeds: http://fordification.com/forum/viewtopic.php?t=1115
Try checking your shift speeds without flooring it which activates the kickdown linkage, try 3/4 throttle.
Barry
What would happen if the modulator is disconnected from its vacuum source and the vacuum source was plugged? I know it will shift later and harder, but how much later? Harder is what I am after so that would be a plus.
- 67F250CS
Hey C.
check out his place. Your question can probably be answered here or it might have already been, if you are willing to scan some of the threads.
Hope this helps you.
http://www.network54.com/Forum/260730
That site was very informative, I ended up putting a longer pin in the modulator. Now it shifts nice and hard at about 4k with you foot in it.
