combo
combo
can you mount a 360 to a np435?
- kaptnkaos
Re: combo
Oh yeah !!! No problemo, the engine just has to be set up right for it... flywheel, bellhousing, clutch etc...
KaptnKA S
KaptnKA S
Re: combo
so if a truck has a inline with a np435 and you wanted to mount an fe what all would you have to do? beside the clutch, flywheel, mounts. would i have to change the clutch? would i have to get different bellhousing?
- papabug71
Re: combo
Im no expert on FE's but im almost 100% sure the 240/300 6's use the small block bellhousing pattern. So yes, you would have to get a FE bellhousing for your NP435.
Correct me if im wrong guys, I am buy no means a FE guru, just trying to help.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Re: combo
, i meant to ask if a bell housing from a t18/fe mount to the np435?papabug71 wrote:Im no expert on FE's but im almost 100% sure the 240/300 6's use the small block bellhousing pattern. So yes, you would have to get a FE bellhousing for your NP435.
- papabug71
Re: combo
Ohhh, that I dont know..........
Matt
Mine since 5/7/'94
Re: combo
when i make this combo will i still be able to use the same driveshaft? i don't know when i mount the eng and tranny back into the truck if it will become longer or shorter.
- fireguywtc
Re: combo
depends on what trans you are replacing. Are you getting this stuff off a parts truck? What motor and trans is in the pickup now? We need all the info.hotrod ford wrote:when i make this combo will i still be able to use the same driveshaft? i don't know when i mount the eng and tranny back into the truck if it will become longer or shorter.
If you currently have a 360 with a T-18 on a 2wd setup, simply replacing that tranny with a np435 shouldn't require any change except the tranny itself.
Bill
Re: combo
i want to take the 360 out of my 71 and put it in another truck. the other truck has a 240 and a np435 in it. i want to hook up the 360 to the np435. i know about the bell hounging and that stuff, but buy putting in a different eng will that make the transmission move fwd, back or stay the same?
- fireguywtc
Re: combo
Transmission sits on the same mount so it should be an issue with moving it.
Bill
Re: combo
Yeah, just use the 360 engine stands in the new truck and everything should line up just fine. I think its the automatics where you have to worry about tranny crossmembers and driveshaft length. Good luck.
Corbin
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
Re: combo
thanks for the help guys. i think this is gonna be a sweet truck when all is said and done.
- willowbilly3
Re: combo
You will have to move the engine towers back. Some/most/all of the bolt holes will line up. Most often you have to drill a couple of them out. Also the 6 and the 8 use a different gas pedal if you are going with all stock carb linkage.
