dana?
hotrod ford
dana?
Post by hotrod ford »
did any swb f100 come with a dana?
Re: dana?
Sure...a few came with a Dana 44 and others with a 5-lug semi-floater Dana 60.
hotrod ford
Re: dana?
how do they compare to the ford 9"? strenght, duribility, perfomance.
AlleyCat
Re: dana?
Post by AlleyCat »
I like them both. I stay with the 9" rears because far more 1/2 tons used them than Dana rears and I'm the type who likes to have spare parts sitting around just in case I need 'em. I've got 3 or 4 sets of axle shafts, a couple housings and 7 or 8 center sections stashed. :lol:
Clay
willowbilly3
Re: dana?
Post by willowbilly3 »
I only drive F250s so I am a D60 person. In a half ton, the 60 might be a little stouter but the choice of ratios is very limited compared to the 9" and the 9 is easier to set up in my opinion. Loose the crush sleeve though and get the shim/spacer set up.
Re: dana?
hotrod ford wrote:did any swb f100 come with a dana?
who is this dana person i keep hearing about? and how come thier age keeps changing from 44 60 70? how old are they anyway? :lol:
green68250
Re: dana?
Post by green68250 »
I have both the Dana 60 1/2 ton and the 9". I will be using the D60 in one of my trucks just because its a semi rare rear end and I think its cool. I have 9"s coming out my ears so if it breaks I can just replace it. If I had to use only one it would be the 9" simply for parts availability.
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
My427stang
Re: dana?
Post by My427stang »
green68250 wrote:I have both the Dana 60 1/2 ton and the 9". I will be using the D60 in one of my trucks just because its a semi rare rear end and I think its cool. I have 9"s coming out my ears so if it breaks I can just replace it. If I had to use only one it would be the 9" simply for parts availability.
Corbin
I agree, and I am in the same situation. However, I put the 9 inch in for now because it was fresh.
hotrod ford
Re: dana?
what if it had 4.10 gears connected to a speed and a 360? would you run this set up?
AlleyCat
Re: dana?
Post by AlleyCat »
hotrod ford wrote:what if it had 4.10 gears connected to a speed and a 360? would you run this set up?
Hotrod ford, you skipped the number but if it's a 4 speed a lot of F250's came that way so my answer would be yes. If I had a choice though I'd much rather have 3.54's in that Dana. They are a good all around gear ratio for a mix of highway driving and low end grunt. :)
Clay
hotrod ford
Re: dana?
oh yeah :doh: , i did. it is a 4 speed with a stock dana 60 with 4.10 gears.
willowbilly3
Re: dana?
hotrod ford wrote:oh yeah :doh: , i did. it is a 4 speed with a stock dana 60 with 4.10 gears.
Depends on the tire but that's a bit deep for a 1/2 ton with 29 inch tall tires. If you have some more like 32-33 then it wouldn't be too bad, wouldn't use it for a commuter.
hotrod ford
Re: dana?
what would this truck had been used for? this is a stock drive train that is in the truck.
willowbilly3
Re: dana?
Could have been used for anything. Trucks were trucks back then and people bought them because they needed to haul stuff. Plus everyone wasn't wound as tight and in such a hurry to get everywhere. It was ok to drive 50-55. Look at over the road trucks. They had maybe 220 horsepower and 6.something gears, topped out 62-65 mph. Nowdays they have to have 450-500 horsepower, run 3.88 gears and pass cars going uphill.
