Fuel filter/pump
1970f100x
Fuel filter/pump
Post by 1970f100x »
Something is banging like hell against my engine block, and when I went to look under the hood, it appears to be either the pump or the filter spazzing out against the block. Now, its the last hose connected to the carb that is connected to the thing spazzing. What is it? and how should i fix it?
Re: Fuel filter/pump
is this the stock pump and filter your talking about or an electric pump and inline fitler?
1970f100x
Post by 1970f100x »
i would imagine its stock. It looks old as hell.
ok i didnt read this too well alst night. i guess i was too tired. the hose and inline filter you have up there is a aftermarket deal its just old . the stock pump and filter are bolted to the block timing cover. my guess is that the pump is pumping fuel into that inline filter and making it jump around or spazzing. which means the pump is good. because itis working. you could just tie it down somehow. or get a fitler that screws right into the cabr and get rid of the inline filter.
1970f100x
Post by 1970f100x »
good news. The problem is now solved. I just tightened all the bolts; including the fuel line bolt. The thing doesn't even shake when it's running, so we're in good business now.
Joshpow
Post by Joshpow »
That'd do it for sure. Glad you figured it out.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
