Power Steering squeel?
1970f100x
Post by 1970f100x »
When I turn my wheel all the way to the right or left, it makes a belt squeel. How should I fix this, or is there no way?
sideoilerfe
Re: Power Steering squeel?
Post by sideoilerfe »
Don't hold it in the "lock" position. In other words, when it is all the way to one side and you feel it stop, back off just a little. You won't notice the difference in turning radius and it'll save your pump. Never hold it all the way in the locked position.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
71 LONG BED
Post by 71 LONG BED »
Start by checking the fluid level, it may need more PSF. Hopefully the bearings aren't starting to sieze. The belt might squeel it the pulley is no longer spinning freely.
John Member #1549
Image Image Image
peanutman
Post by peanutman »
sideoilerfe wrote:Don't hold it in the "lock" position. In other words, when it is all the way to one side and you feel it stop, back off just a little. You won't notice the difference in turning radius and it'll save your pump. Never hold it all the way in the locked position.
:yt: And make sure the belt is tight.
Calvin Gunter
Post by Calvin Gunter »
Also once they develope a glaze on the pulley side replacement is usually the better choice.In the dealership we would sometimes put a light coat of wheel bearing grease in the pulley grooves to quiten some squeals.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
