HELP!!
I just got my C6 rebuilt, and I installed it in the truck, and when I put it into reverse, it just sits there like it is still in park. Same with the forward gears. I have hooked the vacuum line into the trans, hooked up the shift linkage correctly, and filled it with Tranny fluid. Vacuum pressure is 18 inches. I did not rebuild the trans myself, it was done by a professional shop (Mr. Transmission). I would assume that it has been done correctly, but of course, I cannot comment on it for sure.
What do you guys think is the problem here? Where should I look first?
C6 Trans won't shift out of park
- fordtruckparts
1948 Dodge 2.5 Ton, 1959 International Harvester BC-180, 1959 Willys Pickup, 1965 Impala HT, 1965 Galaxie Convertible, 1967 Mercury M-100, 1969 F-250, 1971 F-250, 1976 F250, 1978 F-350, 1979 F-250, 1980 Dodge D-300, 1984 F-250, 1986 F-150, 1987 Chevy Monte Carlo, 1988 F-150, 1988 Mustang, 1990 F-150, 1994 Camaro Z28 LT1
Re: C6 Trans won't shift out of park
I would look over everything I had done first then call up the shop that rebuilt it. Being that they were just in the trans they may have an idea what the problem is.
1970 F-100 360 stock everything
http://s215.photobucket.com/albums/cc21 ... 0%20F-100/
make sure the trans is warm when you check if the fluid is full. then call the mr transmission place.
- AlleyCat
How much fluid did you put in? A C6 with the converter empty holds about 12 quarts of fluid.
Clay
- michael69
Did you get the torque converter seated all the way and flex plate tightened to converter?
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
- fordtruckparts
I did get the converter seated correctly and the flex plate tightened up. I have about 9 quarts of fluid in it. I also re-checked my hookups and everything is correct. I'm gonna warm it up today and see what the level reads when its warm. I am also going to pull the tranny cooler line off to see if there is any oil coming out. I'll keep everyone posted!
- BobbyFord
fordtruckparts wrote:I did get the converter seated correctly and the flex plate tightened up. I have about 9 quarts of fluid in it. I also re-checked my hookups and everything is correct. I'm gonna warm it up today and see what the level reads when its warm. I am also going to pull the tranny cooler line off to see if there is any oil coming out. I'll keep everyone posted!
3 quarts low is why it ain't moving...
- fordtruckparts
Got it working, topped the fluid up to 12 quarts!! I'll never trust my colourblind dad to tell me what the dipstick says again, haha!!
