transmission drags
transmission drags
It seems like the trans in my truck drags it is an auto with a seperate bell housing the trans case is not cast iron but aluminum some one told me that it has double clutchs I dunno. no slips drips or funny shifts it seems to hold the truck back at speeds but when i start raisin h--l with it works good who knows
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
Re: transmission drags
sounds like it might be an fmx trans. the automatics always seem to be sluggish or rob power when driving them kind of like the enigne has the power but it just wont seem to go any faster on the hiway without over reving the enigne. does that sound right? thats what my truck does and it has a c6 automatic in it.
An FMX has a cast-iron main case with aluminum bell- and tail-housing. Since it's got a removable bellhousing, that would seem to indicate a C4.
oops my mistake there. i'm sorry about that. i thought it was the fmx that had the aluminum case. i shoul dhave checked on my facts and not my memory. i have too much info in my head and i am strating to forget some of it and the rest gets kind of mixed up lately
so is the c4 auto any good is there any benifits to other than wallet emptying economy it seems tough cause i pulled skidsteers with it and hauled lots of wood so far. I have a giant cooler on it along with the radiator cooler i even got an oil cooler on the moter it self. I suppose the drag is because the motor is small only a 289 2 V is the balance the same between a 302 and a 289 from the late 60's to early 70's on the fly wheel
- AlleyCat
Yes the balance is the same between the later 289's and earlier 302's. The balance issue becomes a factor with the later EFI 302's but I can't remember what fits what.
The holding back may have more to do with the rear axle ratio than the trans.
Clay
