gear ratio
gear ratio
My 70 f100 has a 9 inch rear end, and 3.23 gear ratio. Is this good, is it stock? Btw, it has a 360 in it.
Re: gear ratio
3.23? are you sure it isn't 3.25. that is a standard size in these trucks. and is a good highway gear. to save gas you need a smaller number or to pull stumps out you need a larger number like 4.11
Re: gear ratio
nope..its 3.23fordman wrote:3.23? are you sure it isn't 3.25. that is a standard size in these trucks. and is a good highway gear. to save gas you need a smaller number or to pull stumps out you need a larger number like 4.11
Re: gear ratio
ok. heres a link to the gear ratio page. http://www.fordification.com/rearends-ford01.htm
- willowbilly3
Re: gear ratio
It's good either way. Most V8 automatics I have seen came with the 3.25
Re: gear ratio
yea i just looked up mine and its a 360 w/automatic. its got 325s. your gona walk off and leave all the bow ties in the dust like i did to my cusin and his pumped up chevy with long gears!
