Slightly off question about an Engine swap
James
Post by James »
Ok. This question probably seems a little weird, but has anyone put in a inline six in a Mustang II?(I believe the years were '74 to '78) I was looking at putting the big six(300) in one, though I'm unsure about clearances and such until I actually can measure the engine bay.
Any help would be appreciated
http://www.cardomain.com/ride/2411268
My '71 F100 truck on Car Domain.
Hawkrod
Re: Slightly off question about an Engine swap
Post by Hawkrod »
As long as you don't plan on using a radiator it will fit fine! LOL A small block is a very tight fit and Ford had to use special components to get the 302 in there, I can't imaging getting anything longer in there unless you remove firewall material. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
my wife had a mustang II i think it was a 74 it had a v6 in it. and that was tight front to back. i had a heck of a time putting a thermostat housing in the lower hose. that was a bad deal.
