intake modification
intake modification
Post by 427 »
I was wondering if anyone has ever modified a F.E. intake by slotting it where the push rods go through? It looks like it could be done but I have never tried to cut them out. It sure would make swapping intakes easier.
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
Re: intake modification
I'm not sure what you have in mind here.
I've seen the pushrod holes enlarged to provide additonal clearance, but you can't cut them all the way through to allow removal without removing the pushrods without devising a way to seal the valley and valve cover rail (among other things).
My427stang
Post by My427stang »
I think they are behind a few port "flanges"
If you cut them so you could pull the intake without pulling the rocker assemblies, I think it wouldnt seal anymore.
averagef250
Post by averagef250 »
I can't see how removing the rockers is such a headache that you'd want to cut up an intake for it. 8 bolts, done.
427
Post by 427 »
I guess I didnt look at the design well enough. It probaly would screw up the intake. Thanks for the replies,Brian.
95 Ford Lightning
38 John Deere G
