thanks
from what i have read i think they will work as long as you get the drop beams for the yr truck you rob the disc parts off of.trick wrote:What if I use droped Ibeams from DJM? will the discs and kingpins fit those beams?trick
Fattz7duce wrote:just want to make sure that i have this write from what i have been reading. i can do the swap on my 72 with 73-79 f250 parts as long as i keep the kingpins, spindles, and I beams from the same yr truck? now are all 1/2 ton and 3/4 ton the same bolt pattern 5 on 5.5? i want to do the swap so i'm going to hit up the junk yard on WED.... i know to talk the steering linkage but should i also take the proportioning valve?
thanks
I read this post for the fist time tonight -- killing some time....Joshpow wrote:You need beams, radius arms, spindles, steering links, proportioning valve, etc from a 73-79 f100 or f150 to keep the correct lug patterns.
