Identify an automatic trans out of a 70 f100
wobblefoot
Post by wobblefoot »
I went to the pick and pull yard yesterday,and found this automatic trans in a 70 ford f100 with a 302.
The only number I could find on it is C97P-7006A.
I know the C stands for 70 something but any other way I dont know how.
Anybodys help would be great. :help:
69 ford f100 Longbed restored 360,auto
71 ford f100 302 3spd shortbed my daily driver
wobblefoot
Re: Identify an automatic trans out of a 70 f100
I made a mistake the number is C9ZP-7006A.
After more looking Ive found C9=1969,Z=mustang,P=automatic.I cant find what the 7006A :? stands for.
thanks.
wobblefoot
I power washed the trans today found a tag on the other side of the casing that looks like its screwed in with screws that says 9 C4,so Im guessing its a c4. :hmm:
flyboy2610
Post by flyboy2610 »
Hawkrod
Post by Hawkrod »
wobblefoot wrote:I went to the pick and pull yard yesterday,and found this automatic trans in a 70 ford f100 with a 302.
The number you found is called an engineering number. That does give you a specific application for a part but does tell you what it was originally designed for. Ford only changes the number when the part is redesigned so in theory you could easily have that C9ZP number on a 79 Ford truck. C9ZP-7006-A is the engineering number for an FMX main case. This means the case of the transmission was originally designed for a 69 Mustang but they were used on almost any car that had an FMX in the 70's until a design change took place. C means 60's, 9 is the year, Z is Mustang, P is transmission and driveline, 7006 is a main case, and A is the version. That number really does not tell you anything unless you happen to recognize it as you can't actually look it up in a regular book and cross reference it. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
