U Joints
- 390F100
U Joints
Where can I buy the rear ujoint which fits the 9" and is off set. I cant find it anywhere. I have a 2 piece shaft...
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
Re: U Joints
Any parts house should have the 'U' joint.
Fred
Fred
- 390F100
Re: U Joints
They do but on my 68 I have a 2 piece drive shaft and a total of 3 u-joints. The front two are exactly the same and are readily available at all parts houses, my problem is that the rear u-joint is not the same as the front two, it is different and the parts houses do not show that, they only have one type listed. I am completely lost and baffled...Any advise or knowledge of what i'm talking about...
390F100
390F100
2007 Suzuki S40 650
2007 Suzuki S40 650
- peanutman
Re: U Joints
Just put u-joints in my70 and all three were the same. Not sure why yours would be different.
1970 302,ps, ac, 3 speed o.d.
Re: U Joints
maybe a car 3rd member, i could easily be wrong but i think they might have a different pinion in them.
Re: U Joints
390 if you take the joint to a parts house they should be able measure it and match it up to something in their catalog, best to go when their not busy. dick
I love my beat up highboy
- averagef250
Re: U Joints
Measure the caps and the cross width. These are "adapter joints". Odds are you're looking at a 1310/1330 cross.
