well after putting a rebuilt motor in the 71 the trans started acting funny.It takes its time to engage in drive
and it flares sometimes.It'll go into drive if you blip the throttle a bit but nothing like it used to.
I've resigned myself to pulling the trans and giving it the go through-my question is what valve body style
is in there?OK laugh all you want I'm a VW guy, automatics still confuse me a bit.
The shifter is a B&M floor mount ,PRND21.When it was working right it'd do the automatic style of shifting
if left in drive but you could start in first and bump it forward for shifts.It shifts harder than most autos
so I'm assuming someone(Hellen Keller and a drunken monkey by the look of the work)did some thing to
the trans.From what I've read so far Broader performance would be a good place to get a kit?
C-4 shift pattern?
- BobbyFord
Re: C-4 shift pattern?
Make sure the modulator valve is hooked up properly.
modulator is a-ok all new hard line and rubber on the ends
is PRND21 a"normal"shift pattern?the POS quit making it move completely today
while the old lady was driving home from work
she say "get a new one"
- BobbyFord
That is the correct pattern.
thanks man
I was almost looking forward to rebuilding it....almost.
