carrier bearing removal
peanutman
Post by peanutman »
Ok i have my driveshaft out and replacing all u- joints and want to replace the bearing as well. Bought a new carrier bearing-the whole thing just not the bearing. Haven't looked at it close yet but the books say nothing. Does the bearing just slip off or is it more complicated than that :?
Thanks! Robbie
heep70
Re: carrier bearing removal
Post by heep70 »
The bearing in the middle of the two driveshafts. No, it takes a press and sometimes a little heat to get it removed.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
peanutman
Post by peanutman »
Thanks heep for the info and quick reply :thup:
kaptnkaos
Post by kaptnkaos »
I recently replaced the carrier bearing in my '68 CS...
I looked all over for a machine shop that could press it off for me... to no avail.
I called a couple of reputable shops in the area...
They use a cut off wheel, which is what I ended up doing.
Cutting as close to main shaft as possible, cut cross ways across the bearing face, trying to be careful to not cut into the shaft.
It took me about half an hour to do mine that way. I could probably do in about half that time now that I have done it and sorta know what I'm doin'
I used a 2x4 and a BFH to drive the new one on.
I have had no problems with it, though I did cut into the flange a couple of times... :doh:
KaptnKA 8) S
peanutman
Post by peanutman »
Thanks kap for the reply. I found a machine shop in irving that will install the u-joints and carrier bearing for $65.00 and i supply the parts. Worth it to me. Thanks! Robbie.
bluef250
Post by bluef250 »
After a day with a Big Hammer, heat, and cold; I had mine cut with grinder. Pressing is the only way and even at $65 (which seems steep), I would press the bearing in a second.
kaptnkaos
Post by kaptnkaos »
:yt:
Yeah especially if ya get the U-joints done too !!!
I'd of dropped $65 in heart beat to have everything done...
KaptnKA 8) S
Darrman
Post by Darrman »
I used a place out in Garland to press the new one on, I cut the old one off. I also found the parts to rebuild the greasable slip yoke on mine. It was only about $20-$30.
69rangerman
Post by 69rangerman »
65.00$? Definately worth it.
I did it all by hand, hammer, wood block, fire, and ice...and it only took most of a week for just the carrier bearing! Sometimes it's just better to pay.
:fr:
JHEBERT
Post by JHEBERT »
peanut man, what is the name of the shop in irving? I live in Fort Worth and I need the same thing done. Also, where did you buy the carrier bearing?
peanutman
Post by peanutman »
JH i bought the carrier at auto zone. Get the carriage, rubber and bearing- should come all put together. It was same price as bearing alone was about $18.00. There are two places in irving. The catipillar dealer and allison dealer. I kinda goofed. i called the allison place but went to catipillar. Took me a while to find someone in shop to help me but they fixed me up.
catipillar is right on hwy, loop 12 at grauwyler and allison is at 2339 e. grauwyler 75061 which is just east of loop12. Allision shop p# is 972-438-1406. Hope this helps. You may also try southwest axle in haltom city 817-654-0020. May be a little closer to you.
Robbie
