No Compression
- jte8969
No Compression
I had put up my truck for the summer because of frustration and just to hot to work outside. My problem is i'm not getting compression. I rebuilt the 352 and had the timing 180 off and bent push rods. I replaced them but now im not getting compression. It has hydraulic lifters so the valves do not need to be adjusted. I have the standard length in there. Any ideas??
1967 F100 project!
- convincor
re: No Compression
is there "0" compression or just real low??
"Still Plays With Trucks"
- jte8969
re: No Compression
I only checked 1st and 5th cylinders. thats all I had time for today and there was 0 compression
1967 F100 project!
- willowbilly3
re: No Compression
If it bent the pushrods it probably bent the valves too.
- convincor
re: No Compression
or the valves are stuck open.
Check and make sure the pushrods are seated correctly in the lifter. Should be able to look down there with the valve covers off. They can get hung-up at the side of the lifter which will hold the valve open all the time.
Can you do a leak down test?
re: No Compression
No compression means either the valves are stuck open or the valve(s) aren't opening at all. Pop the valve cover and watch the rocker arms while you crank the engine see if they move. You can also get a good idea on the condition of the pushrods.
I bought a brand X vehicle several years ago with 0 compression on one cylinder. Popped the valve cover off and saw that the rocker arm had come loose. Reinstalled it, set it, and it ran like a top.
re: No Compression
did you remember to put the pistons back in those holes??? jk like the others stated best thing to do is pop the valve cover and see if they open and close.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
- jte8969
- convincor
re: No Compression
does you compression tester have a airhose fitting? if not, get one that does and hook it up to compressed air. List for where it's leaking from.
here's how- http://www.geocities.com/dsmgrrrl/FAQs/leakdown.htm
or here- http://www.carcraft.com/techarticles/11 ... index.html
With the "0" compression you don't need to have the double gauge set-up. Just need something the connect compressed air to the spark plug hole. You'll be able to hear whether it's leaking out the exhaust or intake.
And you'll want to pull the rocker shafts off when doing this.
Here's a gauge with a quick connect- http://www.partsamerica.com/ProductDeta ... yCode=3491
