I have a 9" Ford rearend laying behind my house and I dont know if it's locking or not.
How can I tell if it's locking just by turning the axles?
thanks
How to tell if axle is locking
- blue68
- convincor
re: How to tell if axle is locking
check the tag if it's there. would read like "3.50L" for locking. gear could be 3.25 or 3.73 etc.
"Still Plays With Trucks"
Re: re: How to tell if axle is locking
You had the right idea, except that the "L" would be located as such:convincor wrote:check the tag if it's there. would read like "3.50L" for locking. gear could be 3.25 or 3.73 etc.
Locking: 3L50
Non-locking: 3 50
And usually just spinning one tire and watching the direction the other one spins will give you the answer, as CO684X4 mentioned. However, a one-legger that's seizing up can exhibit the same behavior, though that's admittedly rare. 99% of the time though, if the opposite wheel spins in the same direction, you do have a limited slip.
- convincor
yep, your right Keith. Was thinking that as I was typing and thought I should confirm, but got lazy
