Any suggestions???
slamd71
Any suggestions???
Post by slamd71 »
I finally decided on a motor. Im Putting a 400M with just over 400 HP with a C6 tranny into my 71 F100 2wd that was originally a 300 straight 6. any suggestions or precautions I should take into consideration to make this swap go a little easier. I was told to leave in the stock rear end... Is this true?
If You're Not Broke Fix It Till You Are
1971 Ford F100 Custom
westernkansas
Post by westernkansas »
sorry i was lost after "I finally decided on a motor"
sideoilerfe
re: Any suggestions???
Post by sideoilerfe »
You could build a killer 300 6 with the money you'd spend on a 400M. JMHO.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
ToughOldFord
Post by ToughOldFord »
Personally I like the 400, it's an underrated engine IMO. But with gas prices the way they are I'd sick with the 300. :2cents:
You'll need engine perches, I forget which ones, but Keith has an excellent write up on perches here.
To be engine correct you'd need to change the radiator support for a V8. Probably going to have to do a custom driveline. Your rear end should be fine unless you want to tweak the gearing to your liking.
ToughOldFord
Here it is:
Comparison Photos of Engine Perches
We don't say it enough, but kudos to Keith for all the time he's put in on this site. :thup:
derek7871
Post by derek7871 »
You might want to replace the front coil springs since you are going from a 6 to an 8. They are different because the 8 cyl. is heavier.
Cooter
slamd71
Re: re: Any suggestions???
Post by slamd71 »
sideoilerfe wrote:You could build a killer 300 6 with the money you'd spend on a 400M. JMHO.
Well I already have the 400 bought and paid for so the 300 is out of the question now haha
19674x4
Post by 19674x4 »
just make sure you got the right mounts and in the right location. keiths writeups are excellent for this kindof project
My Photo Album
slamd71
Post by slamd71 »
Thanks alot for the help guys!!!
