302 swap
mattr67
302 swap
Post by mattr67 »
i did some searching but didnt find what i need. so i have a 67 with a 240 I6 just wondering will a 302 bolt into the 240s motor mounts and what else i will need for this swap
td
re: 302 swap
Post by td »
I know for sure the I-6 frame mounts won't work. you'll need to find some v-8 frame mounts. are you swaping trannies as well?
mattr67
re: 302 swap
Post by mattr67 »
yes i will be swaping trannys too. mine is toast
re: 302 swap
http://www.fordification.com/enginestands.htm
It'll physically work, but using FE/I6 stands for a 302 will cause the engine to sit app. 1" too high, altering the driveshaft angle. The best scenario would be to find the proper small-block stands.
However, you could also just shim up the transmission crossmember a similar amount to match the engine stands. Not the ideal solution, but not totally 'ghetto'. ;)
AK F100
Post by AK F100 »
Wow, good info. Going from memory only, I think my truck has I6 stands and the truck had a 289/302 in it when I bought it.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
averagef250
Post by averagef250 »
You could also swap a 300 in place of the 240 and have more truck power than a 302 could ever dream of.
mattr67
re: 302 swap
Post by mattr67 »
so what do you guys think would be the best v8 for a swb bump. i want power but i dont want to spend alot for it
sideoilerfe
Post by sideoilerfe »
averagef250 wrote:You could also swap a 300 in place of the 240 and have more truck power than a 302 could ever dream of.
:yt:
A 300 is an excellent motor. Visit www.fordsix.com for performance advice.
To be honest, a 300 is best for low end torque. They'll not only pull anything but they'll outlast any V8. They're not high revin' horsepower engines but you can build them to be quite impressive.
:2cents:
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
j41385
re: 302 swap
Post by j41385 »
Add another vote for the 300, and see my signature.
Image Image
mattr67
re: 302 swap
Post by mattr67 »
i found a complete 1981 302 with around 100,000 miles for $150 supposed to run good. but i heard that the 80's engines are smoged down an have less power than 70's engines is this true
GT-Racer
Post by GT-Racer »
if going witha small block why not get a 351w? it is essentially the same swap as 302 and you get a bunch more torque. I have a mild 72 351w making 400 hp. Just a cam, headers, aluminum intake and 4bbl.
80's are definitely down on power from older models.
I may have a set of small block perches if needed. pm me.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
nevrenufhp
Post by nevrenufhp »
GT-Racer wrote:if going witha small block why not get a 351w? it is essentially the same swap as 302 and you get a bunch more torque. I have a mild 72 351w making 400 hp. Just a cam, headers, aluminum intake and 4bbl.
I'd agree with going with the 351W if keeping it small. This 400hp, I'd really like to see with just a cam, hedders, and 4V intake. I built a 351C- 4V(closed chamber 4V heads) that had about $3200 worth of parts in it, and it was 330hp at the wheels. I just dont see 400hp happening with W heads, unless they're aftermarket & high flow....I'm not trying to be pi$$y about it though.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
basketcase0302
re: 302 swap
Post by basketcase0302 »
mattr67,
I don't think any of Ford's I-6's can touch this 302:
http://www.worldcastings.com/prods_page ... r_alum.htm
Hopefully I'll own one of these before I die...
Build it to a 347 stroker and you got one bad-to-the-bone small block. :thup:
Basketcase
averagef250
Actually, I'm pretty sure a bone stock 1V 300 would walk all over that 302 with a 5000 pound trailer in tow.
For a TRUCK you need a TRUCK engine. A 302 may be a great engine, but I can gaurantee the engineers who made it with it's dinky little 3" stroke and light rotating mass had no intention of putting it in a fullsize truck.
And to the mild 351W making 400HP is that with a 200 shot of nitrous? I have respect for the 351W, it does fairly well for it's size. I've done a lot of wheeling with a brute low end torque one in an early bronco, but even being able to pick the front tires off the ground with a hard 3-2 downshift at 25 MPH I seriously doubt it's making more than 200HP and 300TQ.
basketcase0302
re: 302 swap
Forgot how to spell relentless...
There are literally thousands of these documented, want a couple more?
http://uk.youtube.com/watch?v=3zhYTFWAI ... re=related :lolprev:
Basketcase
