240ci/300ci Question
smclaren
Post by smclaren »
Hi Guys
Quick question. Was there ever a factory 2 barrel carb spec for the 240/300 engine. Someone told me the other day that some Canadian trucks had a 2 barrel option on 240/300 from new. Is this right ?
If yes, what's the story with the intake manifold ? My intake supports the 1 barrel only, and I would LOVE to get that 2 barrel option if it exists.
Thanks :thup:
Image Steve - Caloundra, QLD, Australia Image
1969 F100 4x2, RHD, Base Model, 240ci, 4sp, Dealer Canopy, No Bloody Radio.
jzjames
re: 240ci/300ci Question
Post by jzjames »
Ive never heard of any 2 bbl option from the factory. Either make an adapter for the single bbl intake for a 2 bbl carb, or get an Offenhauser or Clifford intake which is set up for 4 bbl carbs, and an adapter can by put on those which would mount a 2 bbl.
j41385
Post by j41385 »
I run a 4v carb on my Offenhouser C series intake. The Offy C lets you choose 2 or 4v, but the offy dp is 4V only. Clifford makes intakes so you can pick a 2 or 4v. Also they have Single 4v intakes, dual 4v intakes, tripple duece, and tripple webber side draught.
Image Image
jzjames
Post by jzjames »
Uh huh. The inline six intakes expert was lurking on here. Hey while youre here, do you have a good source for those Offy-C"s?
j41385
Post by j41385 »
I got mine from JC Whitney. Seemed pretty fair priced. :)
http://www.jcwhitney.com/autoparts/Item ... 8610735552
$264.99 from JC whitney, whereas www.offyparts.com wants $358.49.
Image Image
smclaren
Post by smclaren »
Jamie,
Do the Offenhauser C-series bolt up to the stock exhaust manifold, or do you need to run headers ? :?
Running headers would make most sense to get the performance benefit, but I am thinking a step at a time here.
Thanks :thup:
spartman
Post by spartman »
The offy c-series will bolt up to the factory log, the efi 2 pc and headers.
I think the only headers they may have any issue with are the clifford headers.
theogre5150
Post by theogre5150 »
I have an adapter for a 2bbl carb to a 1bbl intake. I bought it this year but I have now upgraded my setup and don't need it.
spartman
Post by spartman »
One thing I forgot to add is that on my offy c I made an adapter to run GM 2 bbl TBI setup on it.
So far I have gotten it to idle and rev pretty good.
I cant give any info on drive ability since I need a new driveshaft.
j41385
Post by j41385 »
Gosh, What a mess spartman! :P :lol:
Image Image
spartman
Post by spartman »
Its still in prototype stage so :P :P :P :P :P
7DF250
Post by 7DF250 »
Here's another shot of the Offy manifold with the HD Exhaust Log.
nevrenufhp
Re: re: 240ci/300ci Question
Post by nevrenufhp »
j41385 wrote:Gosh, What a mess spartman! :P :lol:
Time for some paint too! :evil:
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
willowbilly3
Post by willowbilly3 »
Hey spart, I think that is a great idea, probably the most bullit proof efi ever. Did you get it into closed loop yet?
I also think it is useless to put a 2 bbl adapter on a stock manifold, if you do have a machinist hog it out down the throat maybe.
So, Jamie, is the C better than the DP for a common street truck? I have a DP and a dual Clifford, no plans for the clifford as yet.
Waiting on that cross flow head.lol
spartman
Post by spartman »
No real exhaust on it yet so no closed loop mode yet.
If all goes well this fall, I will have my garage back and then put the bump in there and get some of this sheet working like its supposed to.
