Sorry guys! I was doing some testing of an error message and accidentally deleted this thread from the database. I noticed it immediately, however, so I was able to hit the 'Back' button on my browser and retrieve the posts. Here are the posts that got deleted:
green68250 wrote:Hey guys,
I just got the 390 back in my '68 F-250 last weekend and got it running. Now whenever I slam on the gas from a stop she dies. I installed a pertronix kit, new plugs, wires, cap and rotor. Set the timing 6 degrees BTDC. She runs great on the open road. Once moving I can slam on it and she taked of like a mad man. Any ideas? The carb is a reman with around 2,000 miles on it. It did this before I did all of the upgrades but not quite as bad. Any help is appreciated.
Thanks,
Corbin
Dragon wrote:What kind of carb. When my truck is hot, with a Holley 4v, and I start it after a hot soak it will smoke and stink of gas but what is worse the next attempt to give it gas will kill the engine. After that it is fine.
green68250 wrote:Its an autolite 2100 2bbl. It idles great. I can give it all the gas I want and snap the throttle and it doesn't die. When I power brake it she stumbles a bit and usually dies when I try and break the tires loose.
Dragon wrote:Replace the Accel pump on the bottom front of the carb or adjust the lever closer to the body of the carb.
I wondered what happened. Thanks for putting it back up Keith, you da man! Anyway, its a reman carb so the accelerator pump should be good I will, however, try moving the linkage in to the next notch on the accelerator pump and see what that does. Just curious, why would moving the linkage like that help the stalling? I'm trying to learn as much about carburetors as possible because the automotive program I am in doesn't teach us about carbs.
Thanks again for your help.
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
I'm sure there are many more out there. hope this helps
Lub
Remember, when someone annoys you, it takes 42 muscles in your face to frown. BUT it only takes 4 muscles to extend your arm and smack the idiot upside the head.
I child-proofed my house.....but they STILL get in!
Changing the lever closer to the body of the carb for the Accel changes how much / fast it gives the accelerator shot of gas...
I would also try bumping your timing up to between 8-10 deg and see if that helps. 6 deg is pretty low for todays fuels...
To bad they don't cover Carburetors in your class. to old school these days I guess...
Shayne
FORDification wrote:Sorry guys! I was doing some testing of an error message and accidentally deleted this thread from the database. I noticed it immediately, however, so I was able to hit the 'Back' button on my browser and retrieve the posts. Here are the posts that got deleted:
Thanks,
Corbin
