putting in new clutch
peanutman
Post by peanutman »
Putting in new clutch kit, should i have fly wheel resurfaced shows little wear. And is a flywheel like a brake rotor, is there a possililty it can't be resurfaced if it has been once before :?
Also this is off of a 302. Are there marks that i need to line up with when it goes back on :?
peanutman
Post by peanutman »
Thanks kap for the reply hopefully someone else will know about flywheel alignment on a 302.
69timemachine
re: putting in new clutch
Post by 69timemachine »
If I remember correctly, my 302 I used to have had the flywheel bolts slightly staggered to where the flywheel would only go on the crankshaft in one position.
Jason
'06 Mustang GT 5-speed
unclejtl
Post by unclejtl »
69Timemachine is correct, I just did mine.
Jason
